Hood Options
Old May 25, 2006 | 03:53 PM
Lee3333's Avatar
Personally, I would much prefer a fiberglass hood. 3 reasons-save weight, doesn't retain heat, and bonding to metal frequently results in cracks due to the metal flexing.
Remember-the cheapest way to make your car faster is to reduce the weight. And, taking it off the front will make the car handle that much better due to an improved front to rear ratio.
Old May 25, 2006 | 04:12 PM
captain howdy's Avatar
Originally Posted by Lee3333
Cowl induction just scoop bonded on. If you look at how they did the install, you will see a picture of the stock hood with the scoop a different color being attached.
I'm pretty sure that's just a mock up to make the mold. For $1000 you better be getting an actual cowl hood rather that a cowl you could buy from anywhere and have bonded on and painted.
Old May 26, 2006 | 09:00 AM
Skatetheglobe's Avatar
do they sell just the cowl like that?
Old May 26, 2006 | 08:55 PM
GPER's Avatar
Hood Answer
I called Teaser today and was told the Hood is a stock OEM HHR hood with a Cowl scoop molded in sanded smooth and primed for the 995.
Old May 28, 2006 | 03:36 PM
BlackHHR's Avatar
Well I didn't want to pay that much for that hood, So I started to make a hood scoop for my 2.2L. I cut out the air flow sencor holder from the stock filter box. Mounted my filter and messured what i need to make. I'm going to make the box mount on the factory spots and make my own hood scoop on top of the air box. Cut the hole in the hood and put weather stripping around it. It might take alittle while as I'll have to do it at work on my time off, but It should work out good.
Just some pix of the filter on right now. It's not noise at all.
Old May 28, 2006 | 05:45 PM
SoCalHHR's Avatar
Black - that short runner length is just not going to cut it. There's a reason companies spend hours tuning the effective runner length.
Good luck with it though!
Old May 28, 2006 | 06:02 PM
BlackHHR's Avatar
Whats wrong with it?
I'm just used of a air filter on top of a carb. Please let me know whats wrong with it.I moved it to the left side of the engine right behind the grill and it worked good for me so far.
Old May 28, 2006 | 11:13 PM
BlackHHR's Avatar
I'm just wondering why it's not good having it that short. I moved it to the drives side infront of the engine and removed the plastic on top of the rad. Air now gets to it from the 2 top holes in the grill. Took it out tonight and there is a ton of inprovment. Lots more pep at low and mid range. A lot better than stock.
LT1GMC
May 11, 2015 10:06 AM
American & Proud
Mods - Exterior
60
Jun 26, 2012 08:13 AM
Zagohhr
Mods - Exterior
0
Oct 13, 2011 09:46 PM
VersysRider
Mods - Exterior
12
Feb 23, 2011 01:00 PM
