Installing Factory Fog Lights On LS
What all is needed to put the factory fog lights on an LS? Wiring and plugs already in place?
At the risk of drawing fire, did you try the SEARCH? Or maybe just look ad the tutorial section of the forum.
https://www.chevyhhr.net/forums/how-...tory-fogs-637/ for instance took me about .21 seconds to find. |
It depend on the car.
My 07 LS needed wiring from the under hood fuse box to fog lights,fog lamp switch, fog lamp relay, wiring from body controller to under hood fuse box and the dealer to program my body controller that the car now has fog lamps. Some cars have more wiring than others. It just depends on what wiring harness was installed in the car. |
Originally Posted by donbrew
(Post 755084)
Search worked fine on my HTC one v.
(Post 755156)
(Post 755156)
H'mm are you using the mobile site? Scroll down to the bottom of the page, bottom left there is a little window probably says "--Sunburst" with a dropdown arrow, choose "Mobile One". That is much easier for fat fingers.
And I have advertised my searching talent for a fee. |
| All times are GMT -5. The time now is 09:31 AM. |
