IPCW Led lights Delivered...
Hello... I got mine another way -- So don't ask how..
Use Maggie ordering site for yours.. But stand by for info.. |
They look good... look brighter then stock....
Fairly simple to install. I recommend a 1/4 drive 8mm deep well socket (due to the long stand offs or threads of the screws) I did find a mold nub , (pic will be posted later) that I had to carefully remove with a razor and then file smooth with a jeweler's file... (This part sits flush with the car body, so if you don't remove it your lights won't sit flush) Heres an instruction sheet supplied.. http://i37.photobucket.com/albums/e7...LEDinstruc.jpg |
what color did you buy? still want to see the smoke installed on something before i order them.
Originally Posted by Yonash
(Post 268537)
Here is the box they come in...
http://i37.photobucket.com/albums/e7...EDlightbox.jpg Here is the mold nub on the part... http://i37.photobucket.com/albums/e7.../nubmarked.jpg |
This pic , on the left is the LED, on the right stock light
http://i37.photobucket.com/albums/e7...klightside.jpg |
In this photo I installed wire bundle protection around the wires..
(I've worked in the aircraft sector long enough and seen wire damage by vibrations) this helps proctect the wire from rubbing on the edge surfaces. I also tie wrap the wires out of the way of each other and hard edge surfaces... The other wire coming out of the hole has a rubber gromment to help it from rubbing on the wire. On the top light assembly the connection goes in fine.. Just for me to ensure it stays, I wrap one tie wrap around both connectors to make sure they stay together.. The lower connector fits snug..(good fit) http://i37.photobucket.com/albums/e7...ireprotect.jpg |
In this photo...
Led rear backup light on left, stock rear backup light on right http://i37.photobucket.com/albums/e7...arbkledstk.jpg |
im getting all giddy waiting for the lit pics on the car.
i too ordered the clears. |
Originally Posted by SLVR FOX
(Post 268548)
i too ordered the clears. My HHR's are Sand Stone & Red... |
