LED conversion 3rd brake light
Looking to match the IPCW LED taillights and not wanting to wait for a third brake light, I took a ride over to Home Depot to pick up a few things to do it myself. Earlier I bought a few LED 921 bulbs off Ebay to replace the stock ones (http://cgi.ebay.com/ebaymotors/2-RED...533QQtcZphoto). I went with the clear lights so I'd have to change the third lens, I'm looking for that seperate light look. Picked up some 5 minute epoxy and Plastikote material (.093) for around $7. Then popped out the factory light. With a large screwdriver (not the drink) carefully pried off the lens from the housing. Using it as a pattern, traced it on the sheet of Plastikote. A Dremel cuts Plastikote like butter. Then Dremeled off the lighting dam, figure it's there for a reason... Cleaned all the mounting surfaces and sanded the new lens in those same areas. Little bit of epoxy and a couple of clamps. Reattaching the light dam to the lens. An hour of dry time and back in the car. Only took a couple of hours for a cleaner look, now if only those taillights would arrive.......
pbatmen
05-19-2007 04:09 PM
