LED dash light swap - pics
anyone done it yet? I searched and couldn't find a thing. I saw tons of dash kits and over lays, but non of the dash lights
I doing this right now, so I was looking for ways to disassemble the boost gauge. The cluster wasn't that bad. So has anyone do it yet? |
if you are talking about the leds which light up the dash. I colored mine with a sharpe, thank to RUDEINC to change the lights them selves I hope you are very good with a iron. I will try to find the thread https://www.chevyhhr.net/forums/show...hlight=cluster
https://www.chevyhhr.net/gallery/fil...8/100_2032.jpg |
ballplr, you forgot to put a space before the thread to get it to come up right.
https://www.chevyhhr.net/forums/show...hlight=cluster |
Originally Posted by an08HHR
(Post 292357)
Although mine are starting to loose their color so I need to color them again. Good luck
yeah I'm pretty good with an iron. I've done a few new model Silverados like this. I'm doing the same thing with this HHR SS.
https://www.chevyhhr.net/gallery/fil.../8/LEDdash.jpg https://www.chevyhhr.net/gallery/fil...022_516407.jpg |
Originally Posted by TooTall
(Post 292363)
do you have any pics of what you are doing on the hhr. I would like to try mine. Mine aren't bright enough and I dont want to color them again
Originally Posted by ballplr
(Post 292365)
and this is completely different ! :confused: These are different, I've got voltage on both sides of the surface mounts . . . and they're small as HECK ! |
(Post 292369)
yeah, I'm taking pics . . . .
and this is completely different ! :confused: These are different, I've got voltage on both sides of the surface mounts . . . and they're small as HECK ! Oh, the good old days when a diode droped 0.7 VDC, period. So in your case, the anode is on the higher voltage side, and the cathode is on the lower. The difference is the drop. A little circuit magic can work wonders. A schematic would be even better. Source BSEET. |
