Malibu wheels. Will these fit our HHR's?
I could of swore that they did but the auction says 4 x 4.33 or 4 x 110 bolt pattern, ours is 5x110
Bolt pattern is 5x110 just like the HHR. Check the offset to be sure.
The auction is all screwed up. The description says 4 lug but lower says 5. The picture shows 5. I looked up the Malibu and it is a 5x110, 38 offset. Should fit fine.
Right on thank you guys. Now if I can only find these for cheaper.:smile:
Those are the wheels I wanted, but did not no what they where off of. I found them here http://www.finishlinewheels.com/PONT...7/A-06585U10N/ E-mailed them and they said they were 17 inch. Only gm wheel I could find like that was a 18. They said they where avalible. I would love to have them. Hope this helps you out. The 159 ones are replicas.Wrong bolt pattern ????
