Saturn Sky Wheels
Hello All
I'm new to this great forum and I have a question for the HHR faithful. I own a Saturn Sky and have a extra set of wheels. They are 18 inch direct Fit with the HHR(putting on Chevy center Caps). My question is will the 245/45 tires be to wide? http://z.about.com/d/cars/1/7/F/R/jf_07sky_20wheel.jpg |
it might be pushing the limit? i would say no but not to familiar what we can run on 18's? a possible sale?:confused: :thumb:
I've looked at those wheels and wondered if they would fit. Would be great if they do, sweet look for the HHR. :thumb:
It'll probably depend on the offset. Stock tires on the HHR are 3 cm narrower than the 245s on the Sky/Solstice.
I run 245/45-17 so It amy be possible. I would think a 235/45-18 would be the best fit.
P225/45R-18 is what comes on my hhr ss. i think the 245 would rub when turning tight.
I guess I can sell the rubber and get 225/45 like the SS... Thanks all
You should at least give it a try first, it would be close.
yeah, i'd like to see results on if there is rubbing or not. i'm looking into going to some 245/40R18 on all 4 corners for my SS, and if those 245/45 don't rub, i should be perfectly fine.
tireman, your tires should be about the same dimensions as what i want to run, what size wheel/offset are your wheels? i'd like to try the 245/45R18 on my stock SS 18x7.5, i know they won't be too wide, as i know a guy who got 255/40 on a 7.5 wheel on an STi (talk about your sidewall bulge there though haha) |
I think I remember on css.net someone said it wouldn't work. Don't let that stop you though, especially since you already have the wheels.
