Chevy HHR Network
-   Appearance/Modifications Discussions (https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/)
-   -   AT shifter knob removal (https://www.chevyhhr.net/forums/appearance-modifications-discussions-6/shifter-knob-removal-65009/)
Mike's 2007 Jan 13, 2022 03:27 PM
Hey folks, just finished reading on here how to remove shifter knob. Well i shifted into neutral and tried my best to push the chrome sleeve down to access the retainer screw but not happening! So i tried to lift the knob thinking i may have read the instructions rong. NOT. Im ready for another solution. Was I suppose to use a screwdriver to pry it down or.....? Didnt want to break it.
Thanx in advance!
Lonwane Jan 13, 2022 03:44 PM
Rotate the chrome piece under the shift knob 90 degrees, then push it down.
Loosen the 2 or 2.5 mm hex screw and lift the knob off.
Shifting to neutral just gives you more room to work.
