Splash Guards
I know there are threads out there for this, but search wasn't working and I need an answer about it pretty quickly. I read earlier today (after I had already ordered a set for $60) that CJ had trouble with the OEM Splash Guards wrecking the paint. Has anyone else experienced the same problems or was his just a fluke? I really need to know so I can try to cancel this order if I need to. THanks in advance, you guys are always very helpful.:bow:
if you make sure that the bottom screw is in and in place w a clip and then make sure the splash guard doesnt move you will be ok
most of the dealers dont put on the bottom screw |
I have the molded HHR splash guards and I don't have one single scratch in the paint from them. I haven't seen anyone other than CJ with that problem yet.
I have those scratches also.
you dont see them till you move them. i will bet that if everyone on the forum w the splash guards moved all 4 of the splash guards so you could see under the wrap around part, you would find scratches mild to worn through the paint to the primer on probably more than 75 to 90%. |
Mine have rubbed through the paint. I was going to get some flaps like you CJ, but I'd have to get it painted before that can happen. I'm just getting some rubber ones to put over top of the factory ones, so that they will hang down lower and protect my side pipes more.
Originally Posted by cj krause
have you moved the splash guards and looked under where they wrap around.
guess you were wrong CH. i guarantee there are others too, Sindy and now Black. most just havent looked. and here u are again w 2 posts making out like i am wrong. if you count you, sindy, black and i. that is 3 out of 4 scratched,,,, 75%. so you are lucky. i put the post along time ago to help people make sure they didnt get scratched and to stop it before it happened and if they add them to make sure they secure the bottom so they dont get scratched. the % may be lower but i have looked at HHRs of people around that i have met up with and most had the scratches. the splash guards for the HHR are expensive and dont work all that great. |
CJ I wasn't trying to make you look wrong. If you reread the posts thats what you did to me and accused me of saying I didn't have any scratches without even looking first. :wtf: I just said that I have no scratches and had not heard of anyone else having that problem but you. Calm down a little. ;)
Now I guess there are three of you so you're not the only one I have heard of with paint scatches under the splash guards any more. :smile: BTW the last part of your statement is an opinion. IMO they work great and are worth the cost because they are the best looking ones out there. |
I hav'nt had any on mine either. I am not trying to take sides in this, but no problem with my OEM splash guard so far.
| All times are GMT -5. The time now is 05:07 AM. |
