Wheels and tires
The more I shop, the more confused I get. My HHR is an LS with the "Plane Jane" 16 inch wheels and hubcaps. I definately want new rims and tires for the summertime and put my "Janes" on in the winter. I have a few questions that I hope some of you experts will answer:
1. What is the width of my wheels now? I see 17" wheels that are mostly 7.5 inches, and a couple that are 8 inches. They have an offset of 45. Will these fit without any problems? 2. If I go to 17 inch wheels and put on the 215 50R 17 tires, will my tire height still be the same for the speedo to work correctly? 3. Some of the wheels say "High" offset. Does that mean at least the 43mm we have now. I know the most logical answer would be to go to a wheel shop and have them try them, BUT I am in far SE Kentucky and the nearest place is about two hours away, and they had NOTHING that would fit an HHR. So, I would have to order them and they would have to work perfectly when I put them on. Whew.........I've typed so much my fingers hurt.....:nuts: |
I would first check with our supporting vendor www.truckshop.com to see what he can get for you. I've recently asked him questions on my wishlist rims and he got back with me very quickly. Another option would be to contact www.tirerack.com.
I've gotten two sets of wheels and a set of tires from Jeff at truckshop.com. Great guy to work with!
I'll see what I can do to answer your questions:
Originally Posted by KY Dave
(Post 137464)
2. If I go to 17 inch wheels and put on the 215 50R 17 tires, will my tire height still be the same for the speedo to work correctly? 3. Some of the wheels say "High" offset. Does that mean at least the 43mm we have now. We do wheel and tire packages quite often, and ship them all ready to bolt on. I've done wheels for several HHRs, but each one is a bit different depending on how the vehicle is going to be set up, if it's to be lowered, etc. Let me know if you have any questions. |
Here's two Jeff helped set-up.
17" Eruomax https://www.chevyhhr.net/gallery/files/1/7/5/1/3.jpg 18" Boyd's (Slayer) got tires too on this one https://www.chevyhhr.net/gallery/fil...1/HPIM0292.JPG |
