| bisho1p |
Jun 13, 2006 07:25 PM |
12 volt source only when ignition is on?
I am looking for a 12 volt source I can tap into that only has juice when the key is turned all the way to the ignition or ON setting. My siren amp is wired directly to my battery, but the thing pulls 5 amps when idle, so for now I have to make sure it is turned off before I park for the night.
I leave it on while driving, because my stock horn is disconnected, and the siren's electronic air horn is used instead. It is wired in such a way that when I press the factory horn, the air horn comes on instead. And when I have my siren turned onto Wail, I can press the factory horn to cycle through the different tones, such as Yelp, and Phaser.
