2006 HHR no power to radio
Old Apr 29, 2020 | 02:52 PM
Matthew M McInnis's Avatar
There is no power to my radio in the HHR. I checked all the fuses in both the inside and under hood fuse box. I ordered the same radio unit on ebay, replaced the radio and still no power to the unit. Is there a short somewhere? What could be the issue? I'm taking it to a mechanic tomorrow to have a lower ball joint replaced, will they be able to provide any insight or am I just wasting my time and money?
thanks!
Old Apr 29, 2020 | 03:08 PM
Welcome to the site, if the guy has a tech 2 scanner he might be able to match it to your vin number.
Old Apr 29, 2020 | 03:11 PM
match the new radio? the new one doesn't power when I connect it either. Can you explain how the scanner would help this issue?
Old Apr 29, 2020 | 03:15 PM
Oldblue. Looks like you and the OP may be almost neighbors ?
Old Apr 29, 2020 | 03:46 PM
Which radio? With amp or without amp. Stock or after market? Did it ever have power? What happened just before it failed? Has anyone been messing with wires anywhere in the car?
You did waste money on a new radio. A new radio needs to be programmed to the car unless has never been installed or the security chip has been replaced.
Fuse #23 inside is the one to look at it should be hot at all times.
Old Apr 29, 2020 | 03:53 PM
It was a used version of the same radio and I planned on getting it programmed but it didn't get power either. The radio didn't work when I purchased the car so I thought it was a dead unit or fuse. The power mirrors also don't work. None of the fuses are blown but I haven't checked if fuse #23 is actually hot yet. Could it be a fault in the fuse box itself or the wiring?
Old Apr 29, 2020 | 04:14 PM
Why did you replace the radio if there was no power to the original one ?
Old Apr 29, 2020 | 04:27 PM
Because I thought, all the fuses were good and the radio was just a dead unit and if I replaced it that would have solved the problem. I am just learning how to work on things. Made sense to me at the time.
Old Apr 29, 2020 | 04:34 PM
You guys recall when Oldblue’s radio went dead last August?
The radio is the radio only difference is the number of CD’s
Now did your new to you radio have anything on the face light up, time or anything?
Old Apr 29, 2020 | 04:36 PM
Some insight from the library
https://www.chevyhhr.net/forums/audi...y-62197/page2/
https://www.google.ca/search?q=radio...iw=375&bih=626
