2008 Chevy HHR Radio Wiring Diagram Help
Old Oct 2, 2022 | 05:05 AM
MunKy_x's Avatar
I need help installing my radio wire harness adapter for my aftermarket radio. I bought this product from Amazon:
here here
And I installed it using the directions on one side of the instructions instead of the opposite side of the instructions like I needed (apparently); it had my car listed on both sides and I didn't look at the other side. I would like to check to make sure the wires match up before I go through more annoying fails, so a diagram or something legit would be great appreciated.
My car is a 2008 LT with just a regular 4 speaker radio, I believe.
Also, I'm having trouble finding a good antenna adapter. Do you know there name of the plug type or whatever? The one I got off Amazon, that said it fits, doesn't. The one I bought is:
here here
It had the male end that I needed.
Here is a picture of the instructions that I was going to try (UPDATE: it worked):
Old Oct 2, 2022 | 06:54 AM
Check the Crutchfield website
Old Oct 2, 2022 | 07:44 AM
Never trust instructions that can’t spell CHEVROLET correctly.
Old Oct 2, 2022 | 07:48 AM
I imagine that the other side just has different names for the Speaker wires, the 2 different radio systems have the same HU only difference is the amp and sub-woofer. What directions are needed for a plug and play adapter? Did you get a GMLAN adapter too?
I see there is a support address on the sheet, did you try it?
Old Oct 2, 2022 | 11:40 AM
It's not plug and play. It's cutting and soldering. All the recent reviews say it's not right.
Old Oct 2, 2022 | 12:43 PM
This is in the Haynes manual.
Old Oct 2, 2022 | 04:23 PM
The usual "not right" is the switched power wire that does not exist. They don't bother to tell you that you need to locate a source of switched power, unless you want to remember to turn it off before you turn the key. Or, do the sensible thing and get a GMLAN adapter and a plug and play adapter.
If you don't get a GMLAN adapter you will no longer have chimes. key in, lights on, turn signal.
Old Oct 2, 2022 | 08:54 PM
MunKy_x's Avatar
Ok, thanks guys. I'll let you know how it goes.
Old Oct 4, 2022 | 09:57 PM
MunKy_x's Avatar
Thanks for that. Using that I matched it to the Red Wolf adapter said and it matched up and I got my radio working.
Old Oct 4, 2022 | 10:03 PM
