Chevy HHR Network
-   Audio and Video (https://www.chevyhhr.net/forums/audio-video-17/)
-   -   2008 Chevy HHR Radio Wiring Diagram Help (https://www.chevyhhr.net/forums/audio-video-17/2008-chevy-hhr-radio-wiring-diagram-help-65709/)
MunKy_x Oct 2, 2022 05:05 AM
I need help installing my radio wire harness adapter for my aftermarket radio. I bought this product from Amazon:
And I installed it using the directions on one side of the instructions instead of the opposite side of the instructions like I needed (apparently); it had my car listed on both sides and I didn't look at the other side. I would like to check to make sure the wires match up before I go through more annoying fails, so a diagram or something legit would be great appreciated.
My car is a 2008 LT with just a regular 4 speaker radio, I believe.
Also, I'm having trouble finding a good antenna adapter. Do you know there name of the plug type or whatever? The one I got off Amazon, that said it fits, doesn't. The one I bought is:
It had the male end that I needed.
Here is a picture of the instructions that I was going to try (UPDATE: it worked):
https://cimg5.ibsrv.net/gimg/www.che...29ef2635b3.jpg
Oldblue Oct 2, 2022 06:54 AM
Check the Crutchfield website
firemangeorge Oct 2, 2022 07:44 AM
Never trust instructions that can’t spell CHEVROLET correctly.
donbrew Oct 2, 2022 07:48 AM
I imagine that the other side just has different names for the Speaker wires, the 2 different radio systems have the same HU only difference is the amp and sub-woofer. What directions are needed for a plug and play adapter? Did you get a GMLAN adapter too?
I see there is a support address on the sheet, did you try it?
RJ_RS_SS_350 Oct 2, 2022 11:40 AM
It's not plug and play. It's cutting and soldering. All the recent reviews say it's not right.
RJ_RS_SS_350 Oct 2, 2022 12:43 PM
This is in the Haynes manual.https://cimg3.ibsrv.net/gimg/www.che...27a4338e00.jpghttps://cimg0.ibsrv.net/gimg/www.che...16fbf6eb95.jpg
donbrew Oct 2, 2022 04:23 PM
The usual "not right" is the switched power wire that does not exist. They don't bother to tell you that you need to locate a source of switched power, unless you want to remember to turn it off before you turn the key. Or, do the sensible thing and get a GMLAN adapter and a plug and play adapter.
If you don't get a GMLAN adapter you will no longer have chimes. key in, lights on, turn signal.
MunKy_x Oct 2, 2022 08:54 PM
Ok, thanks guys. I'll let you know how it goes.
MunKy_x Oct 4, 2022 09:57 PM
Originally Posted by RJ_RS_SS_350 (Post 930418)
Thanks for that. Using that I matched it to the Red Wolf adapter said and it matched up and I got my radio working.
RJ_RS_SS_350 Oct 4, 2022 10:03 PM
:twothumbs:
