2010 2.2L need help with something.
You guys save my car with getting cruise control bag I’ve been browsing the form and I found out from you guys. If the tail light in the middle brake light tail light I don’t know is burnt out. The cruise control won’t work got that done. I fell in love with this car. I’ve had to replace the muffler, the control arms, all four tires, the manifold The cabin filter in the engine filter look like it never been changed since I bought the car oil change Eva system was throwing the PO449 code still dealing with that. And my service tire monitor but those two things are not critical so I’m not replacing right away. I learned from you guys that water gets into the doors right and then it evaporates and it gets in the speakers and it kills them so my speakers in the front and back are not working. Only the tweeters. So does that mean the amp in the subwoofer are bad too? do I need to replace those or am I just wasting money because the subwoofer is not working because the other speakers aren’t working somebody please help me because I am poor and homeless, in school full time to be a barber am living hotel the hotel and I can’t afford to buy things that aren’t necessity to everything working. So some advice some ideas anything y’all got a ****ing game. Thank you. Have a fabulous day.
also, what’s the cheapest way to test a fuse ? |
Pretty easy, to test a fuse
Thank u this will help me check the fuse that’s where I should start before I buy anything rite
Right, and tighten the 4 , 7mm bolts in the under hood fuse box, real tight!!
https://cimg6.ibsrv.net/gimg/www.che...d44376b8a.jpeg Then push the fuses and relays firmly into place. |
Use a test light or meter and do an entire box in a minute.
https://cimg2.ibsrv.net/gimg/www.che...f4419245bb.jpg |
If the key is ON. Not all fuses are "hot at all times".
Either using the mark v optical sensors; if there is a break in the filament it is blown, or a meter and check continuity. A fuse is a bit of wire that melts when a preset amperage is applied. Not magic. |
To be honest I’m a 33 year old gay man who’s a massage therapist and barber. I’m so over whelmed. But I’m going to auto zone and I’m gonna get the fuse checker and try my best to get this done rn
Gay men, massage therapists and barbers don't have eyes? I learn something new everyday.
It is rare for a fuse to blow and not be visibly damaged, it happens but rarely. A "fuse checker" is just a ohm meter, checks for continuity. You can get a VOM at Harbor Freight for less than $10, they are frequently on sale for around $5. A 12 volt light probe is even cheaper. Mark V optical sensors (AKA eyeballs) are included in most humans. |
I got the fancy tester
Why do you mention your sexual preference. Are you looking for more than car info?
| All times are GMT -5. The time now is 12:46 AM. |
