aftermarket cd player???
Old Feb 18, 2009 | 10:13 PM
crunk_no_more's Avatar
hey family, so i bought a JVC cd player nothing fancy, well i bought the dash kit, wire harness, and antenna adapter everything went as normal with the installation, but the cd player will come on then just die, i played around with the wiring now i have it to where the cd plaer stays on all the time it will not turn off lol once i turn the key off the radio and my parking lights remain on, the only way to turn it off is to pull the fuse comming off the battery + terminal. the wiring kit came with an independant red wire i have no clue what this is for im sure it is the answer to my problem so can anyone help me as to where this wire needs to be installed??? and any suggestions on fitting the deck, it is very tight and the cd player is sticking out about 1/8th it just looks like crap thanks alot guys
Old Feb 18, 2009 | 10:18 PM
masterchief1112's Avatar
what wiring harness are you using. they usually come with a diagram that says what wires go where.
Old Feb 19, 2009 | 12:10 AM
cobb28's Avatar
I put in a Sony CDX-GT630UI a couple weeks ago and didn't have any problems but I ordered it from Crutchfield and it came with everything I needed for the install. You may want to call them and ask just a couple questions to get you on the right track. My install looks perfect and is seated very nicely with no gaps and this was my first ever car stereo install so maybe you simply overlooked something, here are the parts I used in case it helps.
I used the following parts for the install on a 2008 HHR LS:
Sony CDX-GT630UI http://www.crutchfield.com/p_158GT63...T630UI&tp=5684
GMOS-LAN-03 http://www.crutchfield.com/p_120OSLA...h=gmos&tp=3486
In-Dash Kit http://www.crutchfield.com/p_142GM15...M1598B&tp=3121
Antenna Adapter http://www.crutchfield.com/p_12040CR...40CR10&tp=2569
Old Feb 19, 2009 | 10:39 AM
thats whats bothering me lol, im very experienced with aftermarket parts, i have had a 2001 toyota corolla totally modded, a 1999 ford crown vic, 2000 mazda protege, 1989 honda crx, all modded i have NEVER had a radio kick my ass like this, here is the kit i used http://www.sonicelectronix.com/item_...a+70-2003.html
Old Feb 19, 2009 | 11:43 AM
cobb28's Avatar
http://www.sonicelectronix.com/item_...+70-2104.html#
Metra 70-2104
Wiring Harness for 2006-up Chevrolet HHR
Old Feb 19, 2009 | 05:15 PM
FlaHHROwner's Avatar
I installed a JVC in my LS and both wiring harness's matched right up wire for wire, lable for lable, was very easy and no issues.
Old Jun 23, 2009 | 01:08 PM
thorn11166's Avatar
Metra 70-2104
hey how did you get this one to work? i couldn't get it to even turn my power my radio
Old Jun 23, 2009 | 02:25 PM
thorn11166's Avatar
what about this one? http://www.installer.com/item/displa...php?it=71-2104
Old Jun 23, 2009 | 07:15 PM
87silver's Avatar
Power Wiring
Most car audio systems have standard color coding.
Red is typically 12V switched (accessory) hot. The source that you derive the 12V for this lead would normally go dead when the ignition is shut all the way off. This will shut down the main operation of the unit.
Yellow is typically 12V constant (battery) hot. The source that you derive the 12V for this lead would always be live, regardless of the position of the ignition switch. This will maintain the system's memory (clock, presets, etc.)
Blue is typically a switched output for an accessory such as an electric antenna. Tape this one off if using it for an HHR.
Black is ground, "the world around". If you don't know what this is, consult a professional :-)
Old Mar 4, 2010 | 04:12 AM
biglefthhr's Avatar
yes however, where is the correct location to connect that 12v switched wire in the fuse box does anybody know?
