Aftermarket Radio/Head Unit
Anyone have any good recommendations for upgrading the stock (non-Pioneer) radio to something more modern and fuctional?
Seems we're limited to 7" display. Wondering if there are any ootions to have a separate monitor from the head unit? The only one I've seen is the Pioneer DMH-WC6600NEX. https://www.crutchfield.com/p_130DMC...WC6600NEX.html Hefty price tag though. |
Exactly where I would shopping, they have a wide assortment of HU. The ones you’re looking at are spendy!!
Originally Posted by Oldblue
(Post 949093)
I'm not sure what you mean by separate from headunit, or why that's important. This is what I just got.
https://www.crutchfield.com/S-ftf5Hn...caAqJUEALw_wcB https://cimg1.ibsrv.net/gimg/www.che...9e393e67d4.jpg I miss being able to quickly reduce the volume with the knob. But the adapter they used retains the mute function of the "call" steering wheel button, so I'm pretty happy about that. |
OP is talking about units with “floating” displays, to overcome the limit imposed by the size of a double DIN.
Crutchfield has several by Boss. Here’s the cheapest one I found. This one is over 10”, has a removable display, and volume knob. Have seen them up to 14”. Backup cam optional. Watch the first vid at the link. https://cimg2.ibsrv.net/gimg/www.che...616138dcd.jpeg https://www.crutchfield.com/p_104BE1...BE10ACP-C.html |
(Post 949104)
Yeah unfortunately that Boss unit's display has to be attached to the main unit and cannot be relocated.You may be better off going with a seperate gps unit that you can mount up higher on the dash.It would be ALOT cheaper .You could still swap your head unit for a better one and save money.
Yes, but looks to me that the display height may be adjustable, but even if not, the pic I posted shows that will be quite a bit higher than the stock unit. Down side, looks like it will block the vents at lease a little. Dunno. Need dimensions.
Originally Posted by Vinnybagodoughnuts
(Post 949164)
https://www.amazon.com/Garmin-010-02...s%2C210&sr=8-5 |
Avoid boss or dual. They are junk.
(Post 949175)
| All times are GMT -5. The time now is 04:47 AM. |
