Chevy HHR Network
-   Audio and Video (https://www.chevyhhr.net/forums/audio-video-17/)
-   -   amp suggestions (https://www.chevyhhr.net/forums/audio-video-17/amp-suggestions-46724/)
skyline26 Jun 25, 2013 09:24 PM
amp suggestions
can anyone suggest an amp that is better than the stock one? i want to keep the stock woofer but dont want to blow it, cuz im sure the woofer can take a bit more power than the stock amp gives out
dr_fosg8 Jun 26, 2013 11:32 AM
I have been considering this myself. I am looking at something like this, http://www.crutchfield.com/p_206PX2K....html?tp=35834
Should add just enough to make the stock sub a little louder and I am thinking it will fit nicely down by the battery.
MsBecky Jun 26, 2013 03:32 PM
I know a small amp that has plenty of real power and also have a very good price . You can pick them up on Ebay from the manufacturer . It is Phoenix Golds repair and service center , so they come with a warranty . It will smoke that little amp from crutchfield ..... It is 125.00 dollars US . Leave the factory amp to power your other speakers .....
I had one , and now have another one along with its big brother . For the dollar per watt value , this little amp is hard to pass up .
Greg
http://www.ebay.com/itm/Phoenix-Gold-Xenon-X100-2-2-Ch-Amplifie-300Watts-90Day-Warranty-Tech-Support-/300810270256?pt=Car_Amplifiers&hash=item4609b07630
dr_fosg8 Jun 26, 2013 04:19 PM
I could be wrong and someone please correct me if I am. The factory sub has dual 2 ohm voice coils resulting in a 1 ohm mono load. That PG amp msbecky listed showed a 2 ohm minimum running bridged which would be no good for stock sub.
skyline26 Jun 26, 2013 04:35 PM
ya its a dual..but becky said to run it along with the stock amp..
dont have the stock amp anyway so that wouldnt work..just need to find a decent mono
prod Jun 26, 2013 04:41 PM
You should be able to run the stock sub at 4ohm by wiring the voice coils in series, then any amp should handle it. Theres a couple kenwood amps on the ont cobalt forum for $40.
MsBecky Jun 26, 2013 04:45 PM
Dual 2 ohm sub .... series = 2+2 = 4 ohms ..
Greg
http://m.seimg.net/product/img/subwo...ch_bridged.jpg
dr_fosg8 Jun 26, 2013 07:22 PM
Gotcha, I was under the impression you had the full pioneer system and wanted to disconnect the factory sub and use an amp with a little more power just for the sub and keep the factory amp for the doors still.
Carry on.
skyline26 Jun 26, 2013 07:33 PM
im always so weary on buying used amps..never know what they've been through or if they will cut out the next day
dr_fosg8 Jun 26, 2013 08:24 PM
Also, just about any major brand amp will most likely be better than the stock amp as far as driving a subwoofer.
