Best Place to wire in rca for subs
from looking at the plug diagram there seems to be a dedicated wires for the sub that is stock, I have the pioneer system in my car and i looking at adding 2 12's to that, i just go the car about 2 months ago so i haven't wanted to dig into it without some research first. So how is everyone connecting (where) the rca's on the stock radio system? And the trigger line? Thanks for the input and any pics would be great!
I don't believe anyone has wired RCA's into the stock wiring. :confused: I wired an RCA line output converter to the stock wiring and then ran the RCA's to my sub amp. The trigger line? :confused: The signal on was pink if that's what you mean. If you want 2 12"s you better be prepaired to run a seperate sub amp just like everybody else. ;)
CH where did your wire your converter in at?
of course i am just wondering where the best place it IE where the existing amp is and if i can just get in there to the (existing Sub) wiring because i would assume that the Eq for that sub is there. Which means there should be a remote turn on there. I would prefer not to have to run wires from the HUD to the rear of trunk. I saw a wire diagram with all the colors but where are all the plugs that are described? the trigger line is 12v turn on. what type of line converter did you use.
Originally Posted by -md- HHR
(Post 112026)
Originally Posted by johnbrum
(Post 112031)
is the amp located in the back by the existing sub?
It's attached to the box. Let me find a pic.
1 Attachment(s)
thanks alot that was exactley what i needed thanks alot for the reply will have my stuff installed soon then.
