broken aux jack
Old Dec 28, 2008 | 07:08 PM
ccsubruce's Avatar
broken aux jack
I have a problem with my aux jack. Apparently, the wire I had plugged in there broke off...so there's a small piece still inside. I need to know how to remove the little piece that's still stuck inside. The problem is preventing me from using the aux jack with my XM radio. Ugh...
Anyone know how to fix this?
Old Dec 28, 2008 | 08:43 PM
ChevyMgr's Avatar
Do you mean like a piece of copper wire? I so maybe someing like a small wooden match with soft wood, that you could stab it with and pull out. Or take the radio apart.
Old Dec 28, 2008 | 10:37 PM
masterchief1112's Avatar
maybe something small and sticky may do the trick
Old Dec 29, 2008 | 06:13 AM
ccsubruce's Avatar
It's not a piece of copper wire that's stuck; it's a piece of the plug that goes into the aux jack. Think of a set of headphones and the plug on the headphones that goes into the jack on an IPOD. The tip of that plug is what's stuck in there.
Notice the two different tips on the wire? The tip on the left was in the XM radio setup. The tip on the right was in the aux jack on the radio in my car.
Why do I get the feeling I'm screwed on this one?
Old Dec 29, 2008 | 07:16 AM
djmoose's Avatar
Good luck...
I'm assuming it's way in there...you're probably going to need to check ebay for a new factory radio.
Old Dec 29, 2008 | 07:33 AM
Len McRiddle's Avatar
Don't those tips screw in to the jack? Can you insert the jack and rotate it CW and see if it threads in?
Old Dec 29, 2008 | 07:53 AM
HHorange's Avatar
I'm afraid your safest bet would be to remove the radio and open it up. Trying to stick anything into the jack to try to remove it from the front may cause it to go in farther and damage the jack. At that point your only choice would be to replace the jack, if you can find an exact match (circuit board mounts come in a lot of differant types) or replace the radio.
Old Dec 29, 2008 | 08:58 AM
id say if ur under bumper to bumper still take it to the dealer and tell them the jack does not work. but that would be dishonest. not like dealers are very honest to begin with. there are the nice ones tho too.
Old Dec 29, 2008 | 09:31 AM
HHR4JK's Avatar
who to say that the jack in the radio didnt help break the end off..... just a thought
Old Dec 29, 2008 | 09:42 AM
ChevyMgr's Avatar
ccsubruce,
Are you still under the 3/36 warranty?
