Color of wires for pin numbers.
I have found a few diagrams for the two connectors that attach to the stock radio in the HHR on this forum. I have a 2009 LT 2.2L with none Pioneer audio system. What I am looking for is a pin out that tells me what color wire is attached to which pin in these connectors.
I am installing an ASWC-1 and the wire connections in the instructions say: 1) Connect the Black wire of the ASWC-1 to Chassis ground. (I'm good with this) 2) Connect the Red wire of the ASWC-1 to a 12-volt Accessory wire, one that turns on and off with the ignition key. (I am not good with this, not sure where this 12-volt accessory wire exists) 3) Connect the Yellow/Green wire of the ASWC-1 to Pin 11 of the vehicle. Below is a picture of what the connector in the vehicle looks like: https://www.chevyhhr.net/gallery/sho...hp?i=39016&c=3 (It doesn't show what color the wire is, so I can't look in my Haynes manual to see what exactly I am connecting this Yellow/Green wire to. I am not good with this. Am I supposed to solder it to the existing wire in pin 11?) 4) Connect White/Green wire of the ASWC-1 to Chassis ground. You may use the same chassis ground as the black wire. (I am good with that) 5) Connect pin 14 of the vehicle harness shown BELOW to a 12-volt accessory wire. https://www.chevyhhr.net/gallery/sho...hp?i=39017&c=3 ( I am not good with that. What does pin 14 go to? Where is the elusive 12-volt switched wire? And again, am I supposed to solder it to the existing wire in pin 14? So if someone has a pin out showing wire colors to pin number I sure would appreciate a copy of that. I thought these modules were supposed to be designed to forgo the need for soldering and splicing. Thanks |
Happy Thanksgiving to all who observe this Holiday.
Has no one else installed the ASWC-1 interface in their 2009 HHR? Just trying to get my ducks in a row before I start pulling things out. Thanks. |
Read your other thread for answers to the switched wire question.
Those directions sound clear to me. It would help to have everything in your hand while reading them. |
Try this temporary link to a pdf file. I'll leave it up for a while.
https://drive.google.com/file/d/0Bx6...ew?usp=sharing |
Thank you very much.:chevyhhrnetrocks: Exactly what I needed.
FWIW, in stock American cars one color wire is almost always the same wire throughout the car. i.e.: a brown wire near the steering wheel will go to the same terminal point as a brown wire in the door. That is why DVOMs are so cheap (Harbor Freight <$10), to make sure it is.
(This is a response to a post deleted by the OP. The burden of a mod is that they can read deleted posts.:sad: that's sad not mad) |
donbrew,
On the pdf you posted there seems to be some kind of number or alphanumeric label on the gray wire coming out of pin #2 on the 14 pin connector (X1), can you read what it is on your end? A lot of my problems are stemming from the fact that I do not have a wire attached to #2 in the 14 pin connector(X1). I am trying to find out where this wire either originates or occurs again. Thanks |
At the end of the arrowhead it says interior light system.
The other end says supply voltage. The grey wire on 14 says 10volt reference going to the steering wheel control. |
Thanks
