Compustar / Remote Starter on 5 speed HHR LT
Hi Guys,
Just got my compusar intstalled on my HHR LT and love it i was wondering if anyone else has installed a compustar on a manual car with a remote starter? I have a question regarding the radio which tends to stay on for 10 mintues when the car is turned off? Is there anyway to change this? anyways love the install job donw on the car... Wouldn't part the HHR anywhere with out a 2 way alarms... Guys post your questions or answer to mine. Thanks Nick
Originally Posted by nabate
...I have a question regarding the radio which tends to stay on for 10 mintues when the car is turned off? Is there anyway to change this?
1) Turn off the radio button.
2) open/shut the driver door quickly; the radio shuts off as soon as the driver's door opens.
Hope it helps,
Oh......and
Nick!
Sure, they do it all te time now using a neutral safety lockout.
The HHR must be left in neutral (hopefully on level ground!), with the parking brake on.
If the vehicle is left in gear, the engine won't start.
yes you have to leave the car in neturel and follow a saftey procedure... Works great on the manual, i knew the compustar would work don't know if there is any other ones out there that will allow for a remote starter. Anyways i'll try the open and close door quickly right now i need to tuen the radio off.
Thanks guys i did test the open and close door theroy and it works like a charm. I now just turn the radio off as it shuts off after 5 mins. with the hot weather its so nice to go to an aircondintioned HHR thats nice and cool.
For a while I would park my metro where it could drive in a strait line to the front door of my office. I would screw with people by remote starting my car and let it drive to me, then arm the alarm again which would stop the car. I got to the point where I could do it with pretty good precision. God the stupid stuff we do when we are younger.
Ours were not the packaged kind though, we did it with the third or fourth channel on our alarms and a bunch of relays. The remote start would turn on the car, the neon, and the stereo. One of the relays we put on later was on the parking break sensor, the sensor had to say the parking brake was engaged before the remote start would initialize.
it can be done in about an hour by someone who knows what they are doing. if you are just following the instructions w/ out a clue, it can take much longer.
as for the one to use i dont know, we did ours with a viper alarm and an endless supply of relays.
