Direct Wiring for 2006 HHR with 7 speaker system and Amp
(for those who choose to keep the factory amp and change the head unit) (or those who wish to use the factory amp with a carputer) ------------------------------------------------------------------------------ [Harness 1] Battery(+) = [RED/WHITE] Ground(-) = [BLACK/WHITE] Left Front Low Level = [DARK-GREEN(-)] [TAN(+)] Right Front Low Level = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)] ------------------------------------------------------------------------------ [Harness 2] Amp Turn On Signal (same as power antenna) = [PINK] Left Rear Low Level = [BROWN(-)] [BROWN/WHITE(+)] Right Rear Low Level = [TAN(-)] [DARK-BLUE(+)] ------------------------------------------------------------------------------ The ignition line will have to be sourced elsewhere as it is controlled by the GMLAN. Check the fuse panel to the right of the center console for a source. [Hint](Power windows work after you shut off your car, until you open a door!) |
(for those who choose to keep the factory amp and change the head unit) (or those who wish to use the factory amp with a carputer) ------------------------------------------------------------------------------ [Harness 1] Battery(+) = [RED/WHITE] Ground(-) = [BLACK/WHITE] Left Front Low Level = [DARK-GREEN(-)] [TAN(+)] Right Front Low Level = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)] ------------------------------------------------------------------------------ [Harness 2] Amp Turn On Signal (same as power antenna) = [PINK] Left Rear Low Level = [BROWN(-)] [BROWN/WHITE(+)] Right Rear Low Level = [TAN(-)] [DARK-BLUE(+)] ------------------------------------------------------------------------------ The ignition line will have to be sourced elsewhere as it is controlled by the GMLAN. Check the fuse panel to the right of the center console for a source. [Hint](Power windows work after you shut off your car, until you open a door!) You can also grab accessory at the ignition harness http://www.directechs.com/timages/acc_6041.jpg It's the brown wire there |
(for those who choose to keep the factory amp and change the head unit) (or those who wish to use the factory amp with a carputer) ------------------------------------------------------------------------------ [Harness 1] Battery(+) = [RED/WHITE] Ground(-) = [BLACK/WHITE] Left Front Low Level = [DARK-GREEN(-)] [TAN(+)] Right Front Low Level = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)] ------------------------------------------------------------------------------ [Harness 2] Amp Turn On Signal (same as power antenna) = [PINK] Left Rear Low Level = [BROWN(-)] [BROWN/WHITE(+)] Right Rear Low Level = [TAN(-)] [DARK-BLUE(+)] ------------------------------------------------------------------------------ The ignition line will have to be sourced elsewhere as it is controlled by the GMLAN. Check the fuse panel to the right of the center console for a source. [Hint](Power windows work after you shut off your car, until you open a door!) http://n8zcc.com/pics/HHR/Audio_Connectors.pdf |
| All times are GMT -5. The time now is 06:43 AM. |
