GPS Install Speed Pulse Location
Does anyone know where I can pick up the speed detection circuit speed pulse signal? I'm guessing it is probably available at the BCM, but I have no idea which wire it is.
Thanks very much! |
The GPS shows the MPH, unless you are tring to show the difference. Mine is really accurate.
Thanks. I'm pulling out the premium sound system and installing a Pioneer AVIC-Z1. It uses the signal to maintain accuracy when the GPS signal is not present, so I need to get to the signal to connect to the receiver....
I looked this up for HVROD but never heard if it worked or not. Here is what I sent him....
If you have an automatic, then the ECM C3 (Gray) connector: Pin 66 YELLOW Vehicle Speed Sensor Signal High (w/M86) Pin 67 PURPLE Vehicle Speed Sensor Low (w/M86) |
Where are those located??
