aftermarket radio installation
Old 07-25-2018, 11:24 AM
Cliffs51's Avatar
The 1Lt i bought recently had a single din aftermarket radio in it that did not sound or work good. Whoever put it in installed a toggle switch where the 12v power outlet was so itvstayed on even when the key was out which i also didnt like. I have my new double din now andvwhen i took out the old radio i found a mess of spliced in and taped in wires. This is a picture of the only harness connector i see. The new radio does come with a speaker wire plug in. My question is should there be another factory connector or is it just the one? Thanks in advance. The PO tells me it was that way when he bought the car in 2011
Cliffs51 is offline
Old 07-25-2018, 11:29 AM
That appears to be the harness plug for the single din radio you removed, quite the wiring mess! A poster picture for how not to wire in a modern radio .
Crutchfield should have something in the line of directions
Oldblue is offline
Old 07-25-2018, 11:40 AM
Cliffs51's Avatar
Yeah its a mess. Im afraid the installer threw away the factory connector or connectors. Do you know if there are one or two factory connectors?
Cliffs51 is offline
Old 07-25-2018, 12:14 PM
I believe two , but mine has the Pioneer system so it might be different
Have a look here
https://www.crutchfield.ca/learn/200...rolet-hhr.html
Oldblue is offline
Old 07-25-2018, 12:24 PM
Cliffs51's Avatar
Yep two. Looks like ill be making a trip to lkq in the morning for a factory connector. Ive got every thing else from cutchfield
Cliffs51 is offline
Old 07-25-2018, 12:37 PM
Cat Man HHR's Avatar
PM hellshotrod he parts out HHR's and might help you with a harness plug.
Cat Man HHR is offline
Old 07-25-2018, 01:02 PM
Cliffs51's Avatar
I would but im putting it in tomorrow and hes in California. I know lkq has the part and itll be cheap
Cliffs51 is offline
Old 07-25-2018, 01:42 PM
Technical Moderator
You could exercise the search button. I have posted the plugs and diagrams lots of times.
Try going to my gallery, look in post pictures.
Which code on the glove box door? UQ3,UW5.
I'm sure you know the obvious answer to "where do I get OE connectors for my GM car?". The other answer is anywhere they carry Dorman.
donbrew is online now
Old 07-25-2018, 07:20 PM
Cliffs51's Avatar
Thanks Don. I figured out that factory is two plugs by looking at the adaptor from crutchfield. The idiot that installed the existing radio must have thrown them away.
Cliffs51 is offline
Old 07-25-2018, 10:15 PM
tiapetra's Avatar
Perhaps I'm missing something here.
If you have a new double DIN radio to install, I don't see the point in reinstalling the OEM connectors. Each brand/model of radio or head unit has it's own connectors and the GM OEM connectors won't fit.
You have to cut the existing butchered setup out anyway, so why don't you just connect the new radio connector that came with the new radio to the car wiring.
The color codes are both here and with your new radio.
Soldering the connections along with heatshrink is as good as it gets.
tiapetra is offline
Quick Reply: aftermarket radio installation
