How to access stereo wires for a dvd head rest monitor
Hello, Didn't know if there was a way to access the stereo wires. We recently purchased dvd headrest monitors, but the only way to install them is connecting the power wire to the +12 volt power supply of the car. I am not sure if it is too hard for me to figure out or I should just take the monitors back. Thanks
I just installed some in mine - the easiest way is to get a fuse tap and hook them up to the sunroof fuse in the fuse box - its in the passenger side of the center console - really easy - and its powered if you have a sunroof or not.
Originally Posted by comic75
(Post 461898)
Constant hot
I installed an overhead DVD player and an aftermarket stereo and used the empty #21 slot in the fuse block in the passenger side of the center console. Make sure you plug into the correct side or you wont have any power. It has worked great so far and was alot easier than running out to the main fuse block in the engine compartment. I found pictures and everything on which one to connect to on another post on this site. WHAT A GREAT SITE IT IS!
Do you remember what post by chance? Thanks
| All times are GMT -5. The time now is 05:13 AM. |
