Chevy HHR Network
-   Audio and Video (https://www.chevyhhr.net/forums/audio-video-17/)
-   -   How do I run an aftermarket amp with factory head unit (https://www.chevyhhr.net/forums/audio-video-17/how-do-i-run-aftermarket-amp-factory-head-unit-1814/)
slamed87lincoln May 2, 2006 06:21 PM
im just wanting to keep the factory head unit for now but am wanting to run an amp and 2 12s...what do i need to get to run the rcas to the amp?
Tokyo May 2, 2006 06:37 PM
A high-to-low level converter. I suggest you use a PAC unit, but your amp probably has high-level inputs as well. You would t-tap the lines going to your door speakers, usually the rear set (most people fade to the rear in stock form). If you've got the factory amp, you t-tap off it's outputs.
BlackHHR May 2, 2006 06:41 PM
There is no right way. I did hook up my RCA's to the wires that go to the factory sub. It worked for me untill I ripped all of it out. I don't recomend doing this. :nono:
Come on CH I know you have something to say about this.:2cents:
captain howdy May 2, 2006 06:51 PM
Tokyo nailed it, that's the best way. :beer: Even though the mono amp I am going to use to drive my sub has high level inputs I am still using a line level converter. To my knowledge using the high level inputs on the amp can lead to more clipping as opposed to using the RCAs. I could be wrong but that's what I gather. :confused:
Skatetheglobe May 2, 2006 08:04 PM
I used the line level converter also..
slamed87lincoln May 2, 2006 10:09 PM
well im wanting to keep the factory amp to power 7 speaker system from the factory.....im just wanting to add 2 12s....where do i get the converter?
captain howdy May 2, 2006 10:12 PM
A car audio shop. Even Walmart has them.
slamed87lincoln May 2, 2006 10:21 PM
ok ill look into it
JT's HHR May 3, 2006 07:38 PM
I used rca's and tapped into the speaker wires between the deck and stock amp. I have not had any problems.
I have the premium sound and didn't use the line converter because the wiring diagram says they are low level inputs.
slamed87lincoln May 3, 2006 08:18 PM
what did you do to "tap" into the speaker wires....how would i connect the RCA into the speaker wire?
