How to wire Kinivo BTC450
I just got a Kinivo BTC450 bluetooth hands free car kit and I would like to wire it so that its not plugged into the cigarette lighter outlet because it is getting power when the car is turned off. I would like to have it wired so that it gets powered on when the car is turned on and powered off when i turn off the car so that it does not drain the battery. Could someone please help me out, I have looked around and not sure how to do it. Any help is appreciated. Thanks
Moved to the audio/video forum, because this is not a "How-To".
Probably the best fuse tap location would be the RAP fuse (Retained Accessory Power). Or one of the other fuses that are tied to the ignition.
I am sure the answer is available via the search tool at the top of the page, but the quickest way is to just grab a voltmeter and start checking the power at the fuses in the passengers footwell (left side).
