I might be a lil retard? please help
I have the diagrams for hooking up the subwoofer but theres 4 wires i only need to so what ones do i pick. pin A and C or pin B and D or all 4
http://n8zcc.com/pics/HHR/Audio_Connectors.pdf |
i have the converter to tab into to, put just need help picking the 2 wires thanks
I don't understand the question? :confused: A little better explanation of what's going on and what your trying to accomplish might help. ;)
(Post 131687)
ok I hooked it up to the box but i cant get no audio to the amp and i turned gain up on the box but now i was wondering do i just tap into the lines or do i disconnect them from the factory amp and run them to the box or keep them connected to the amp
Do you have the Pioneer system? I take it your amp is properly connected to the battery, grounded correctly, and you tapped the factory remote turn-on lead if you have the Pioneer system?
yes every thing is connected right the amp comes on its hooked up but cant get now sound so was wonderin what else i could try cause I have JL 10W7 and a 500/1 amp but cant get no sound to the sub but i know i unhooked the sub wires because my speakers still work but my old sub dont. and do i have to keep the old sub wires connected or can i disconect them from the factory amp or do i need to keep them connected to the amp. so there connected to the old harness yet.or just take them of the old harness and run them to the jl amp or keep them hooked in the harness and split them and run them to the amp to
I conected my sub after the factory amp.
see i disconnected them from the factory amp so the dont go to it anymore so when i plug in the harnesses into the amp the sub wires arnt there instead they go my converter then to my amp
could i go to the low level and not the sub
