I replaced my 8" sub (again).
Originally Posted by Skatetheglobe
Ok so I have heard 2ohm stable for an amp.What makes it 2ohm stable?
This may be oversimplified, but you should get the idea.
Originally Posted by AlienHHR
Most car audio is designed for 4 ohm speakers, so that is what most manfacturers design car audio components around. But higher end audio goes for the maximum effeciency to effectively double an amps output (50W@4ohm = 100W@2ohm - is that right, somebody in audio correct me if I'm wrong). Keep in mind that 0 ohms is a dead short. As you get close to 0 ohms your components have to have tight enough tolerances to not see it as a short and overheat. So if your amp is 2 ohm stable, it will work with setups that present a 2 ohm load.
The 50w@4 ohms and 100w@2 ohms is correct as long as the amplifier is designed to produce the voltage and current need to push the signal into the speaker load. Check your amplifier's specifications, it should show the load and power ratings it is designed to operate at.
Speakers are rated at a nominal (or average) resistance because they do not offer a constant resistance value.
When working with AC as we are with audio signals, we must consider the effective values of the voltage and the current often referred to as the RMS values. The analog to Ohm’s laws is I = V/Z where I is current, V is voltage and Z is impedance.
Just to be politically correct, resistance is the opposition of direct current (DC) flow and impedance is the opposition of alternating current (AC) flow.
