XM Help
Old 04-28-2017, 08:42 PM
fosser2@gmail.com's Avatar
XM Help
I've seen a bunch of posts with you providing some help to individuals regarding XM installs. I currently have a 2015 Chevy Impala Limited LS (9th gen I believe?) and I'm trying to figure out if XM is built into it. I believe the answer will be no, but my curiosity has peaked. When I press the CAT button on my head unit it displays XM Feature. While I go through the bands it only shows AM/FM.
This being said is there any way to have XM installed on this model if it is not already there? I also dug through my trunk in the right hand side behind the side carpet as people mentioned in some other posts. I attached a picture of the module that I found, but I do not believe that is for XM. Thanks so much for your help!
fosser2
fosser2@gmail.com is offline
Old 04-28-2017, 11:53 PM
Being this is a forum for HHR's, and not Impalas, you are probably better off checking with a forum that deals in Impalas. Locate the RPO sheet for the car (likely in the glove box?) and see if XM is one of the options listed as being installed. Use Google to find a list of the possibilities of the RPO codes.
That said, a quick google search of the part number on the picture you posted, shows it is a FUEL PUMP RELAY - GMC - Fuel Pump relay MODUL - 20964304: Used Auto Parts | Mercedes Benz Used Parts | BMW Used Parts
whopper is offline
SpaceCowboy
01-27-2012 02:28 PM
gotboost
11
01-20-2012 07:30 PM
an08HHR
04-20-2008 09:26 AM
NEXTIMAGE
02-08-2008 04:26 AM
Quick Reply: XM Help
