Problems with Stereo Install
Old Apr 10, 2006 | 12:40 AM
wheelsee's Avatar
oook so I just got back inside after three hours in the 40 degree weather...I just got the itch to do it tonight...first off much thanks to Mike @ SoCal HHRs as he got me the stereo kit from CA to MD in two days and also for the wiring diagram as it made things pretty easy however...you might wanna edit it to say the Red Cable with the White Line for Power...
it looks like also there is a problem with the kit as my trim piece doesnt wanna go back on and the problem is at with the clip that goes in the kit in the middle...
but overall I'll be happy the only other problem I had was me being stupid and not putting the inline fuse together for the XM Add-On(which blew the 15A behind the passenger wheel well panel(which wasn't labeled and I had to guess and I got it right the first time))once I get everything back installed me and my friend are gonna prolly hold off til tuesday to finish it and clean up the install which is also including a Pioneer XM Add-On Tuner...
-wC
Old Apr 10, 2006 | 12:51 AM
SoCalHHR's Avatar
I put the same exact kit in mine Wheelsee - did you cut the tabs off the top as it says in the directions? Sorry about the power cable mixup - I took my power dorectly from the RED cable feeding the center console fusebox. That way I have stereo power without using the keys. (I should have mentioned that on the diagram!)
So, explain the rest of your problem...(I'll see it tomorrow - gotta go now!)
Old Apr 10, 2006 | 12:58 AM
wheelsee's Avatar
directions...oh man...that would probaly be what the issue is then...no other issues other than cleaning up the install...and putting the car back together...but there is power and sound to all four speakers right now so I'll be happy for the drive to work...
-wC
Old Apr 10, 2006 | 07:26 PM
wheelsee's Avatar
ok so one issue down...once I cut those tabs the panel poped right back on...now I just can't get the radio to slide all the way back in...
-wC
Old Apr 10, 2006 | 07:34 PM
O6ChevyHHR's Avatar
souldent be that hard, just make sure that you have no wires in the way, dont force it in there.
Old Apr 10, 2006 | 08:18 PM
SoCalHHR's Avatar
-wC
TECH SUPPPORT!!!!
Hey wheelsee - the antenna cable is probably stopping the radio from going all the way back.
a) pull radio out almost all the way and feel back there with your hand. If the cable is wrapped around the back move it over to its routing hole.
b) do what I did anf cut a big gaping hole in the back so there's NO PROBLEM running the wires out!
Hope you get it handled soon bro!
Old Apr 10, 2006 | 08:22 PM
wheelsee's Avatar
I'm gonna give it another go tomorrow morning with fresh light...one thing though the radio doesnt turn off when I pull the key out...
-wC
Old Apr 10, 2006 | 08:28 PM
-wC
Everyone here does know that the radio will still play w/ the key out until the driver's door is open. Just checking.
Old Apr 10, 2006 | 09:24 PM
jaydogg's Avatar
mine doesnt do that anymore. you turn the key the radio turns off. i tapped the acc under the dash if that makes any difference.
Old Apr 10, 2006 | 09:50 PM
wheelsee's Avatar
yes I do know that...no the radio will turn on without any keys in the car at all...
-wC
