Which is power antenna lead?
Old 09-16-2017, 08:49 AM
Wdavidferrell1964's Avatar
if I pull the panel where the right tweeter is, which wire is the power to the am/fm antenna?
thank you.
Wdavidferrell1964 is offline
Old 09-16-2017, 08:58 AM
Since you didn't state a year or model, I'll take a generic shot.
The pink wire.
firemangeorge is offline
Old 09-16-2017, 05:23 PM
Yep pink wire!
Oldblue is offline
Old 09-16-2017, 08:33 PM
Originally Posted by Oldblue
Yep pink wire!
which is what I thought, but when I hook the power antenna lead from the stereo up to the pink wire, it makes no difference in the signal. FM radio stations 35 miles away are just empty spots in the dial.
Old 09-16-2017, 08:49 PM
Your amplifier may be bad. Here is a thread for you. https://www.chevyhhr.net/forums/prob...problem-38716/
RJ_RS_SS_350 is offline
Old 09-16-2017, 09:05 PM
its not a premium system. I replaced the stock radio with a Kenwood but the stock stereo had the same horrible radio reception.
Old 09-16-2017, 09:16 PM
Not that amp, the antenna amp, did you even look at the thread I linked?
Cokeybill
12-19-2008 07:07 AM
n.j.hhr
North East
57
09-02-2007 08:48 AM
Nor-Cal HHR Club
05-19-2007 05:43 PM
TomsHHR
08-24-2006 08:30 PM
donn758
01-30-2006 12:19 PM
Quick Reply: Which is power antenna lead?
