Radio Bass & Treble Resets Itself
I have a 2009 HHR SS. On the radio display, I'll go the menu to set the Bass/Mid/Treble where I want it. On random occasions, without rhyme or reason, the radio will reset these (i.e., go back to flat sound). I'm clueless why this happens randomly. Has anybody seen this before?
(note: on a few occasions where I've disconnected the battery, it will reset to flat sound and under those circumstances, I'd expect that behavior; but not at other random times when battery power has been maintained) Thanks in advance, M Ridzon |
Kinda answers your question, loose ground wire or power wire , loose radio fuse.
Just like disconnecting the battery a loose point of continuity will reset the radio |
Originally Posted by Oldblue
(Post 828605)
Just like disconnecting the battery a loose point of continuity will reset the radio M Ridzon |
Here's my experience, probably won't help you, but maybe. For over a year, when I would plug into the aux port, I would get a high pitch background sound. It got louder as I turned up the volume, but get it loud enough, it wasn't as noticeable.
I tolerated it till recently, when occasionally the display would start to spaz out. Some of the preset buttons don't work either, so I figured I really needed a new headunit. Well, one time the display started to spaz out, for some reason I thought I would try something. I gently, but firmly, pressed the faceplate in. The display cleared up. A bonus was that the high pitch noise went away also. I occasionally still have to push in the faceplate. So something is loose, but probably internally, and beyond my ability to fix. I'll still get a new headunit someday. I finally figured out how to set the time. The preset button for the hour works, but the one for the minute doesn't. I pulled the RDO fuse today, and replaced it at the top of the hour. Now I can adjust the hour until the clock is right again!! :twothumbs: |
So still something electrical is loose. Possibly internal
