radio issues?
Old Jan 4, 2006 | 01:15 PM
Riggs's Avatar
Originally Posted by GeeMac
What I noticed with mine is that there is not enough volume and the fade between front and rear is not the greatest. I think a better set of speakers in the back would remedy this. As far as reception, it is far better than my wife's '02 Mustang. No problems with it cutting out or anything like that -- so far.
Thank you for the feeback, adding rear speakers just is not in the budget right now,.
Old Jan 4, 2006 | 06:31 PM
GeeMac's Avatar
Originally Posted by SoCalHHR
Before you spend a bunch of dough on rear door speakers, read my post HERE.
Might save you some money - as the head unit is "lacking power" in the rear speaker outputs.
Hope it helps,
Thanks for the excellent step-by-step guide.
Old Jan 6, 2006 | 08:46 AM
Phantom06HHR's Avatar
Originally Posted by SIHHR
1) This is a repost
2) A fellow HHR member had a similar issue and there was a loose connection in back of the unit.
3) Thank you
well sorry to say but this is not a repost. Here is a quick update folks- on wed of this week i went out to take the hhr to a buisness meeting. 100% dead car. No lights were left on, and no door was open. Found out the hard way that when there is no power at all, you cannot shift the hhr from park! Imagine trying to jump the car in a garage with only 8 foot cables, my god did that suck. After getting it up a running i drove it to the dealer as the radio had completely stopped working the day before, so i had planned on taking it in anyway.
So, the radio (premium 6 disc) is being replaced, and they are still trying to find out what caused the battery to die completely. On a side note, the turn signals stopped making the blinking noise as well. Hopefully everytnig will get fixed, but it is going to take until next week to know what has happened as the dealer is perplexed.
BTW, i had pushed down all the fuses when we bought the car, and i checked them again before i took it in, and they were all loose again, even with the fuse cover installed properly.
Ill try to keep you guys more informed as i know more.
Old Jan 6, 2006 | 08:54 AM
captain howdy's Avatar
That sucks! Hopefully the dealer gets it all fixed quickly.
Old Jan 6, 2006 | 08:59 AM
adamlowery's Avatar
wow. Talk about your bad luck. sry man
Old Jan 6, 2006 | 05:39 PM
no udates today
Old Jan 6, 2006 | 06:28 PM
SIHHR's Avatar
Yeah having the battery drain does not sound right. That's a very unique issue. Please keep us updated about what casued these issues.
Old Jan 6, 2006 | 06:29 PM
SoCalHHR's Avatar
Originally Posted by Phantom06HHR
Imagine trying to jump the car in a garage with only 8 foot cables...
Why would this be hard? It's just like starting any other car. The Red Positive cable goes on the "+" Terminal, and the Negative cable goes on the driver side strut tower bolt. Am I missing something from your post?
Old Jan 7, 2006 | 10:07 PM
crazybob's Avatar
Yeah, it was in the garage. I assume he means the cables wouldn't reach.
Old Jan 8, 2006 | 06:32 PM
steinywihhr's Avatar
hey SoCal is there a small mono amp that I can install to boost each speaker??
Steiny
