radio issues?
Old Jan 9, 2006 | 08:48 AM
Phantom06HHR's Avatar
Originally Posted by crazybob
Yeah, it was in the garage. I assume he means the cables wouldn't reach.
exactly. both car batteries were on the drivers side of the vehicles, with the hhr on the right side, facing in
Old Jan 11, 2006 | 08:30 PM
well, it turns out the radio was the culprit all the long. it was drawing power even with the acc turned to the off position. Replaced and everything is good to go
Old Jan 12, 2006 | 09:09 AM
Riggs's Avatar
I have experienced a problem with my radio, a couple of times now when I have turned my car on, there is a very loud pop over the speakers, sounds like a short or a feedback problem. I thought that the first time it was because I was in the garage and it was the xm, but it has happened a couple of other times since then, out in the open. Any ideas what could be causing this? It only happens on start up and it is very sporadic.
Old Jan 12, 2006 | 09:48 AM
captain howdy's Avatar
Do you have the amplified premium system? It sounds like turn on thump to me but you would need an amplified system for that to occur.
Old Jan 12, 2006 | 11:03 AM
Riggs's Avatar
I did get the stock premium set up.
Old Jan 12, 2006 | 11:26 AM
  #26
BIG JIM WOODMAN's Avatar
Pop Noises From Radio
I HAVE HAD THIS HAPPEN MANY TIMES, I.M TAKING MINE IN SOON TO BE LOOKED AT. DOES NOT SEEM NORMAL TO ME.
Old Jan 12, 2006 | 11:43 AM
  #27
There are a couple of things you could do to take care of it but seeing as how it is the factory setup and under warranty I would let the dealership repair it rather than trying to fix it yourself.
Old Jan 12, 2006 | 12:25 PM
  #28
Riggs's Avatar
Thank you!
Old Jan 12, 2006 | 12:26 PM
  #29
Riggs's Avatar
Let me know what you find out, I would appreciate it.
Old Jan 12, 2006 | 02:29 PM
  #30
wheelsee's Avatar
I was gonna say why didnt he just pop the trunk and jump it straight from the battery in the back...but then I remembered that GM forgot to include the manual trunk release...this is why I have one of these
-wC
