Rear door speakers inop
Old May 16, 2020 | 11:07 PM
JOHNNYO's Avatar
No sound rear door speakers. Rear speaker woofer is muffled. Do i have a broken wire or is there a fuse for a separate amplifier. Front door and pillar tweeters are working. Any ideas would be helpful. The HHR is a 2009 2LT.
Old May 17, 2020 | 07:13 AM
You most likely have dead speakers, I suggest you replace all four of the door speakers first.
Old May 17, 2020 | 07:51 AM
JOHNNYO's Avatar
Thanks i was afraid of that. Nothing is ever simple with this car.
Old May 17, 2020 | 08:02 AM
1st thing I would check would be the front -rear Fader adjustment on the radio.
Old May 17, 2020 | 10:22 PM
JOHNNYO's Avatar
Checked the fader no rear door speakers. The sub woffer works but is muffled ,when controls are set to rear so now what? Guess ill get new door speakers and go from there.
Old May 18, 2020 | 07:42 AM
Yes, door speakers first
Old May 19, 2020 | 07:04 PM
08LaRam's Avatar
I had the same problem and went to the audio store and was told my rear speakers were bad. I thought it was strange both speakers going out at the same time. But alas, that is exactly what the problem was. Replaced speakers now good as new.
Old May 22, 2020 | 11:52 AM
JOHNNYO's Avatar
Did the sound to the woofer improve?
Old May 22, 2020 | 01:27 PM
The woofer isn't tied directly to the rear door speakers, It's on its own circuit and has its own amp. But... with the rear door speakers operating properly the woofer may "seem" improved to the human ear..
Old May 22, 2020 | 01:30 PM
Woofers do not have a clear sound. That being said, it's a small woofer, so it could be blown. But the amp is not all that powerful either, so it's hard to say.
