Sirius Connect compatibility w/factory radio
Old Jan 17, 2010 | 03:15 PM
gwizz's Avatar
I tried Crutchfield and thr tech I talked with said the Sirius connect wasnnt compatible with my 09 HHR.
Old Jan 17, 2010 | 03:28 PM
oneton's Avatar
Why is it listed under 09 HHR ? oh well keep looking/
Old Jan 24, 2010 | 06:14 PM
bowtie3's Avatar
Well I tried the SIRGM-1 from the Avalanche and no luck I order the SIRGM2-L from TSS radio because it said it work with the vehicles no listed on the SIRGM-1. No luck again the SIRGM2-L bolts right to the exact XM location and the harness fits, but doesn't work......I had read somewhere that the SIRGM-3A was the fix to the SIRGM-2L but I can't find that one anywhere Oh well guess I will have to suck it up and deal with XM or starting looking at the SCCI set ups....and let the stereo shop figure that one out.
Old Jan 25, 2010 | 07:22 PM
bowtie3's Avatar
OK Talked with TSS radio today and they said that the SIRGM-3A was never put into production and that the SIRGM2-L was the fix all. Then they said that the HHR has a different radio and the only thing that might work for the HHR is the PXAMGM-2 however it stops at the 2008 model year, Does anybody know what if any changes from the 2008 to 2009 and beyond changes in the radio. Does anybody have the wiring diagram for the HHR XM radio harness and the sirius SIRGM1. I am thinking that if some of the pins can be moved around to make the SIRGM1 work. I am sure there are alot smarter people out there has tried this and I don't want to try and re-invent the wheel. Or I guess I will have to give the PXAMGM-2 a try at a later date. Thanks all this site is wonderful and very useful
Old May 24, 2010 | 11:13 PM
MB1's Avatar
MB1
Interesting video from peripherals on their adapter.
http://www.youtube.com/watch?v=kPZFe...eature=related
Used with their cables you can connect a SCC1 Sirius tuner or a
SCVDOC1 for a portable tuner (Stratus 5 for example).
The factory radio may need the XM port activated before this will work.
I don't have the $200 to $250 to try this myself yet.
Also the after market guys appear to be buying each other out,
so model numbers seem to be changing.
06STLHHR
Feb 4, 2014 07:29 AM
tucsondivots
Jul 5, 2012 08:38 PM
bigjacksauto
Dec 9, 2011 04:24 AM
BluetoothManiac
Jul 9, 2007 06:22 PM
