Getting a tech at Crutchfield that nows what's up with the HHR is like going to the casino, sometimes ya win, sometimes you wonder what the hell you went there to begin with! LOL
BTW, no onstar in my car either. |
Originally Posted by GDZHHR
(Post 197020)
And if the stereo doesn't fit the adapters they offer, it "doesn't fit". Like any double-DIN stereo won't fit our car because they don't carry the Metra or Scosche double-DIN trim adapter. |
(Post 196979)
I've got a Pioneer HU and ALL of my chimes work fine. Only thing I lost was the tic-tic of the turn signal; still get the warning chime for leaving the signal on though. Even kept the use of my sterring wheel controls!:thumb:
I have also seen mentioned somewhere that you can wire a relay into the GMOSLNA03 to get the tic-tic for the turn signal - the relay controls nothing, it is just used as a mechanical noise maker. I've ordered a GMOSLAN04 for my system (not from Crutchfield) . I hope I didn't make a mistake, 'cause I'm still confused about the amplifier situation and the 04 is for amplified and the 03 is for non-amplified. I would also like to do the steering wheel controls, but I don't have the remote for my HU and I'm not sure I can program the adapter without it. |
Some progress?
I have removed the wired in harness for the aftermarket head unit and wired up the HU to the GMOS-LAN-04 harness/adapter. It's all very clean with the two factory radio plugs connecting into the GMOS-LAN-04 harness with no extra wires. A quick test has the chimes and the Onstar working! However the output of the HU is very low, I have to turn it up to full volume just to get something loud enough to listen to. I have a few more things to test and questions for Metra tech support. One thing I'll say for Metra support is that they are very quick to respond. I'm still waiting to hear back from Pyleaudio support. I did find an error in the previous installation. The front left positive lead was crossed with the front right positive lead. |
Sounds like you're getting it worked out.
| All times are GMT -5. The time now is 08:14 AM. |
