Speaker size
I understand that the sub is an 8 inch. What size speakers are in the front and rear doors???
Also, I spoke with Crutchfield and they told me that if I replace the factory radio, it will disable the various warning chimes. Any truth to that? |
2 Attachment(s)
Yup their right, and you can fit a 6 1/2" in the factory openings. I'm swapping my factory speakers and sub out for Audiobahn:
Attachment 45194 Attachment 45195 |
depth
will the depth on the audiobahn be the same as the pioneer and are you using the factory amp and radio
Also, I spoke with Crutchfield and they told me that if I replace the factory radio, it will disable the various warning chimes. Any truth to that? Go to a real stereo shop. They'll hook ya up with the right parts... |
Originally Posted by crazybob
WHAT?! The Crutchfield rep didn't know about a chime adaptor?
Not to push it, but what about 6 3/4? I saved my 4 Rockford Fosgate's from my 93 Saturn SL2, and was hoping to use them.
I should also probably upgrade the sub amp. Due to the cold weather, I haven't had the chance to pull off the panal yet. Anyone know the size or power of it? |
I don't think a quarter of an inch will make that big of a difference. You could always open the hole up if necessary. I know systems power is 260 watts total but I dont know how much of that is the head unit and how much is the amp. As far as physical size of the amp I don't know yet, but I'll measure it while I'm doing the speakers
Thanks. As soon as I get time (and hopefully warmer weather) I will also begin tearing things apart. I also want to check the panal that is on the passanger side to see if there is any usable storage space behind it (I built panals in my last car in each corner that had a locking door. It was perfect for holding an extra quart of oil and other small stuff and kept them from tumbling around in the trunk.)
ok i have put an after maket head unit in my hhr and 6 1/2 compants 6 1/2 in the door and tweets in the pillar and yes i have played with the wiringing on the head unit with out a hiring harness for the car it does disable the door chimes i have a set of kenwoods compants in the hhr
www.promotiontuning.com 1-877-724-6682 phillip |
