Stock radio low level input questions?
Old Mar 14, 2008 | 04:09 PM
tahenke's Avatar
Question Stock radio low level input questions?
Ok, yes I have read the above how to on tapping into the subwoofer low level input wires to the factory amp. Problem is that some of the links for the wire diagrams are broken. I hate cutting up the factory wires if I can avoid it. I have added a Parrot bluetooth device to my radio so far and bought a special harness to adapt it to the radio. Since I have done that I now have wires I am willing to cut (I don't mind cutting into this harness because it can be replaced or removed) but I need the pinouts / color codes to the plug that directly connects into the back of the factory deck. This should be low level at this point till it reaches my factory amp. Plus I am upgrading everthing (not just the sub) so I need front left and right signals and the remote turn on. Any help out there? Thanks in advance.
Old Mar 14, 2008 | 05:42 PM
shaginwgn's Avatar
This is for an 2006 HHR but should be the same. I have added it to my favorites on internet explorer before for referencing http://n8zcc.com/pics/HHR/Audio_Connectors.pdf
Old Mar 15, 2008 | 11:45 AM
tahenke's Avatar
Thank you sir, that is perfect!
SteveMaine
Dec 23, 2014 01:04 PM
hhrumadbruh
Oct 18, 2013 09:42 PM
paulstanley19147
Jun 24, 2012 11:26 AM
TiggersHHR
Apr 8, 2012 08:45 AM
ramsfootball86
Feb 17, 2009 12:36 AM
