SWC aftermarket stereo
Sure. You just need to get the correct adapter. Been discussed numerous times over the years on these forums. The most mentioned reference is to contact Crutchfield for the correct adapters to go with your model radio.
I got this one from eBay, it said it retains steering wheel controls but it does not. I did look through our forum but couldn't find any information about it. I did go to crutchfield's it's like pulling teeth to find where the units are, finally I found it but I'm unsure of which one I need any help would greatly be appreciated.
If you didn't get directions with it, I would go to the scosche website and get one, or the crutchfield site (to be a broken record).
Maybe GoOgle "scosche gm25 instructions" or other terms as required.
The one with the audio plug is needed.
This particular module is not available anymore on crutchfields.
Go to the Crutchfield site.Add vehicle info.Pick a Pioneer radio.Click on accessories.The site will show you which adapters you need.Easy peasy.
