Upgrading the base unit
Hi, I am curious about a couple of issues with the stock basic stereo setup in the LS model. I haven't pulled back the rear panel to look, but would the wiring exist for the sub and amp if you don't have the premier system? There is a grill in the rear panel for a sub so I'm hoping there may be attachments and wiring in place for the sub as well?
I want to add an 8" sub in the side panel, replace at least the 2 front door speakers and add an amp to the factory head unit with minimal hassle. And, it has to be completely hidden/stock looking.
I'm not looking for a lot of bass, just good clean sound for my country music. :)
If most of the pieces are in place, I'll could try this myself. If I have to run new wiring, then I'll need an installer to do it. I'm not confident enough to start pulling carpet and whatnot.
TAK
0
May 10, 2012 07:53 PM
Stumpy Knucks
Jun 17, 2008 03:43 PM
