Chevy HHR Network
-   Audio and Video (https://www.chevyhhr.net/forums/audio-video-17/)
-   -   Use existing XM antennae (https://www.chevyhhr.net/forums/audio-video-17/use-existing-xm-antennae-48329/)
jczboy Nov 5, 2013 07:54 AM
I have had the same question... And an extender does not connect to the OE connection, Still looking for a good solution, I would love to see pictures of what someone did.
SpaceCowboy Nov 5, 2013 07:43 PM
it will...take the plastic OE part of the antenna off...then plug your extender or XM tuner box in.
I have a pioneer XM tuner plugged directly into the factory antenna in the rear of the car...
this isn't hard guys
Heavywrecker Nov 12, 2013 11:36 PM
SpaceCowboy is right, but I believe he means you need to remove the plastic BLUE tab from the XM antenna, and voila! Extend it to your hearts content
SpaceCowboy Nov 13, 2013 03:14 PM
right on wrecker
jczboy Nov 21, 2013 07:51 AM
Finally did it, I removed the panel in the right rear that covers the XM module. Unplugged the antenna (Mine had a tan colored connector) Once you remove that connector, it will plug right into the extension. I got a 10 foot one off Amazon for $10, after cutting a couple places where it was taped to other things, ran it along the headliner, down the A pillar, over the glove compartment, and behind the radio. Where I have the new XM module. I did put some heat shrink around the connector.
Thanks SpaceCowboy!
Heavywrecker Nov 21, 2013 12:17 PM
Glad you got it all set up and working!
SpaceCowboy Nov 21, 2013 01:47 PM
Thanks SpaceCowboy!
good job dude!
LazyScamp Mar 6, 2014 05:41 PM
Can you unplug the antenna from the back of the receiver and extend from there?
