Chevy HHR Network
-   Audio and Video (https://www.chevyhhr.net/forums/audio-video-17/)
-   -   What are my chances on blowing my sub? (https://www.chevyhhr.net/forums/audio-video-17/what-my-chances-blowing-my-sub-27409/)
hatetoorun Jan 2, 2010 09:25 PM
I am intalling a Kicker CVT 8". I currently have a Kenwood amp sitting in the closet that has a 300w RMS and a max 1000w. I am scared to install this amp. What are your thoughts?
IgottaWoody Jan 2, 2010 11:03 PM
If the speaker is rated higher then the amp then no problem.....other way around ,and one day you or somebody forgets and cranks it and pow.......you get the sweet aroma of fried voice coil!!
hatetoorun Jan 2, 2010 11:28 PM
Thats the thing..... the kicker cvt 8 is rated I think 200rms and 5-600max.
Some one on this board has this same amp and sub. It just seems dangerous to me, even with the amp tuned down. Hell, I might have to dish out more money to buy a new amp.
CavittyCreep Jan 3, 2010 01:07 AM
depends on how you wire and it depends on your enclosure
is it the 8104D amp? wire the coils in series, turn gain down, and you should get a useable response but not the best sound...bridge it in parallel and call the fire dept
class d gets hot so keep it in an open space
you get what you (will or won't) pay for ... spend a few bucks and get a good amp
bigw10921 Jan 3, 2010 05:59 AM
I've seen more speakers blow from trying to produce crap from an underpowered amp...Trying to get a speaker to produce the sound of a distorted amp clipping at high levels can blow the speaker easily....I usually run speakers that are under rated for the amo i am using and leave the amp mid way up
hatetoorun Jan 3, 2010 09:04 AM
Alright, a new amp it is. How is the Alpine MRP-M500? It seems to have the perfect power specs.
