Chevy HHR Network
-   Audio and Video (https://www.chevyhhr.net/forums/audio-video-17/)
-   -   XM and P.A.L. install (https://www.chevyhhr.net/forums/audio-video-17/xm-p-l-install-14627/)
jzr28 Apr 21, 2008 09:30 AM
I just bought an 08 HHR and it did not have XM from the factory. I am having the dealer upgrade the radio to XM and having a P.A.L. installed too. They can get the XM to work OR the P.A.L. to work but not both at the same time. They are in contact with Chevrolet but so far Chevy has been no help. Has any one else done this and if so who did the work?? I would like to be able to point my dealer to someone who is knowledgeable about this install. THANKS!!!
ChevyMgr Apr 21, 2008 09:48 AM
A message from GM about on month or more ago stated do not add the PAL and XM due to compatability concerns until GM worked out a fix. The dealer should of known this.
jzr28 Apr 21, 2008 10:03 AM
THANKS!!! Called the dealer and they said Chevy had told them the same thing this morning. This is a pretty good site!!! :bow:
ChevyMgr Apr 21, 2008 10:05 AM
Here is the original posting. See post #38.
https://www.chevyhhr.net/forums/show...t=12882&page=4
I'm sure they will get this worked out sooner or later.
JeffsHHR Apr 21, 2008 11:32 AM
so if i'm reading this correctly....if you had your XM installed at the factory...you can have the PAL installed. If XM was added at the dealership...then you cannot have PAL installed.
ChevyMgr Apr 21, 2008 11:59 AM
Correct! I had no problems at all.
sweet_william Nov 26, 2008 09:36 AM
I know this is an old posting, but for future reference, my XM was factory and I installed the PAL myself. I have horrible problems with XM constantly switching from whatever channel I'm on to XM0 for a second and then back. BTW, the PAL instructions were backwards and I can't find out anything from GM about any fix in the future. A pretty damn shotty accessory, and you have to drill holes and solder wires making it hard to return to stock.
ChevyMgr Nov 26, 2008 09:49 AM
Who did the original programming after you installed the PAL? My install did not require any drilling. There is updated programming that will fix this issue.
https://www.chevyhhr.net/forums/show...2882&page=7#62
jzr28 Jan 6, 2009 11:02 PM
Got it working
HI all - I have not been here for a while and came back to update my email address. I did finally get the P.A.L. installed but the dealer took it to a stereo place to have it done. It seems to be working OK. It has quite a bit of lag in it going from XM to iPod but not too bad. Mine also seems to stop every now and then and say Ipod disconnected when it really isn't but that does not happen very often. Just some FYI :).
