Any issues with KYB struts
I have a LT '11 . The previous owner replaced one front strut. And boy is it noisey. I want to do both front struts and am hoping the KYB are good and don't make noise.
Would you please share the part number of the KYB struts that you have used successfully? I have a 2011 2LT and it doesn't seem to ride as well as my previous 2011 2LT and I am looking for replacements.
Thank you
Thank you
No, if you’re not using lowering springs.
The Quick struts include struts, spring top plate and bearing , new springs bump stops and bellows.
No need to compress the springs , struggle with the nut or worry about parts flying and smacking your drywall, grille, passenger side door, or worse .
