Bleeding ABS brakes. Just need to verify something.
Old Apr 18, 2014 | 01:08 PM
skuzzlebutt's Avatar
When a person is bleeding brakes on a car with ABS. Does one need to always use a scan tool to pulse the ABS when bleeding or is that only if you are replacing a component which might introduce air into the ABS system? Meaning this..... If im doing just a standard pad and rotor swap and want to flush the brake fluid as one should depending on mileage. Then im good to go with only a typical bleed procedure? If theres no air in there now and i keep the master cylinder full (in my case will be using a Motive pressure bleeder) then using a scan tool to pulse air from the ABS is not needed?
Haha sorry about the needlessly long question.
Thanks
Old Apr 18, 2014 | 01:17 PM
jczboy's Avatar
You will be fine. Good idea to do the flush
Old Apr 18, 2014 | 01:18 PM
No. There is no difference in the procedure. Start farthest from MC, have lovely assistant press on pedal on command. Or, use a 1-man bleeder, I got the vacuum type from Harbor Freight for about $12.
blacky
Maintenance and Upkeep
7
Jun 8, 2014 09:05 AM
blacky
Jul 10, 2013 01:33 PM
pnad
2.0L Performance Tech
Jun 27, 2011 10:07 AM
dnutbrown
Sep 16, 2010 03:32 AM
EVSS
Apr 15, 2010 04:06 PM
