Chevy HHR Network
-   Brakes | Suspension | Shocks | Struts (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/)
-   -   Bleeding ABS brakes. Just need to verify something. (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/bleeding-abs-brakes-just-need-verify-something-50285/)
skuzzlebutt Apr 18, 2014 01:08 PM
When a person is bleeding brakes on a car with ABS. Does one need to always use a scan tool to pulse the ABS when bleeding or is that only if you are replacing a component which might introduce air into the ABS system? Meaning this..... If im doing just a standard pad and rotor swap and want to flush the brake fluid as one should depending on mileage. Then im good to go with only a typical bleed procedure? If theres no air in there now and i keep the master cylinder full (in my case will be using a Motive pressure bleeder) then using a scan tool to pulse air from the ABS is not needed?
Haha sorry about the needlessly long question.
Thanks
jczboy Apr 18, 2014 01:17 PM
You will be fine. Good idea to do the flush
donbrew Apr 18, 2014 01:18 PM
No. There is no difference in the procedure. Start farthest from MC, have lovely assistant press on pedal on command. Or, use a 1-man bleeder, I got the vacuum type from Harbor Freight for about $12.
