Brake pedal height adjustment
Hi,
I have had a Low brake pedal since I got My HHR. My question is there an adjustment rod coming from the power booster to the brake pedal ?My HHR is a 2007 LT1 2.2Liter . New brake shoes and Pads. bluwing |
No adjuster for the pedal; but.. that usually means the shoes on the rear need adjusting. You should only have 3-4 clicks on the hand brake.
Also, what is your definition of 'low brake pedal' ? Is it resting close to the firewall, or is it just soft, or ??
I thought I had a low one. I confirmed with at least one other experienced member who indicated that his pedal firms up a couple inches off the ground. Mine has always been that way no matter how tight the rear drums are. Also, I test drove a couple HHR's feeling out the market over the years and they all feel the same way. The pedal is naturally kind of "soft". At least softer than any car I drove before. Anyone else want to chime in to confirm or deny?
Originally Posted by aradmahogany
(Post 821786)
But this is what I mean, 'low' means different things to different people. |
If you want a hard pedal, cap off the vacuum hose.
Hi Don,
Low pedal on mine is about 2 Inches from the floor. It is a hard Pedal. The brakes are new. You mean the Vacuum Hose from the Motor to the booster? It kinda scary if you need to Make a panic Stop! Apparently The Newer models 2010 and 2011 Might have the adjuster. Some where in My Manual "Chiltons" I read Something about turning the rod out a few turns. Thought I Bookmarked it. Now I can't find the page. I assume They meant the one from the Power booster. Thanks for the reply!!! Thanks again Don, bluwing |
Check your brake fluid also.
If you have new pads etc. did you also bleed the brakes and was it topped off? Simple things first. |
It could be your master cylinder is headed south!
This member had a similar issue https://www.chevyhhr.net/forums/prob...mystery-30810/ |
Originally Posted by donbrew
(Post 821793)
I can't find any reference to an adjustment to the pedal in Mitchell OD. There is something about shims for the brake light switch (curiously they don't call it a position sensor). |
| All times are GMT -5. The time now is 05:13 AM. |
